CSV content from SQL field to Features
mlupien
Forum|alt.badge.img+7
Hi Community,
I need to extract a CSV Style content from a SQL field of an SQL table.
It is stored into a single field.
The content looks like this:
Classification,Fonction
03-1,300
03-2,301
AA-10,C-1000
AA-12,C-1000
AA-15,C-1000
AA-17,C-1000
AA-20,C-1000
AA-22,C-1000
AA-25,C-1000
AA-27,C-1000
AA-30,C-1000
As you can see, the first line gives me the Attributes names and the following lines gives me the values
What would be the best way to turn this into multiple features using the first line as the Attributes names ?
Thank you
Best answer by nielsgerrits
One way to do this:
  • Explode lines to features by newline.
  • Explode the attributes to features by comma.
  • Split header and data.
  • Merge headers to data.
  • Create attributes from headers and data.
  • Merge back into lines.
  • Expose created attributes.
Yes, you need to expose the attributes. No this can not be done dynamic. :-)
The only dynamic thing you can do is to create a schema feature using the SchemaScanner to write the result with dynamic generated attributenames.
One way to do this:
jkr_wrk
Forum|alt.badge.img+29
  • May 2, 2024
Solution without a featureMerger:
mlupien
  • May 2, 2024
nielsgerrits wrote:
One way to do this:
Great ! Thank you !
For now, I can manually expose the attributes. I will give a try with the SchemaScanner for sure !
mlupien
  • May 2, 2024
Hi, @jkr_wrk ,
The concept looks interesting, but I can’t figure out what your “AttributeSplitter_3” is doing. What would be the parameters ?
and how do you link the link the header with the data after ?
Thank you
jkr_wrk
  • May 4, 2024
I thought AttributeSplitter_3 was simple but after a second look I see I had to puzzle that myself as well.
It creates the _list_headers{} from the _list{0} . This _list_headers{} is used in AttributeCreator_3 to make it the AttributeName. This is a bit tricky because you put @Value(_list_headers{@Value(_element_index}}) in the AttributeName field.
_element_index is the index of the AttributeSplitter_2 which splitted the value.
mlupien
  • May 5, 2024
OMG ! thank you @jkr_wrk for the explantation, I was not able to figure out by myself !
