Custom CRS website not accessible anymore
delunama
Participant
This website (https://demos-safe-software.fmecloud.com/fmedatastreaming/Coordsys/Start.fmw) used to be accessible to public - it transforms your custom ESRI Projection WKT and provides you with a zip file of the following:
How can I get access to it ?
Best answer by daveatsafe
Hi @delunama,
The FME Flow running that process was updated to 2024, which required some updating to the process to conform to the new security procedures. Please use the following URL from now on:
Create Custom Coordinate System
Or for a much simpler link, please use the shortcut:
fme.ly/coordsys
donalmateer
Hi @delunama
We are currently looking into this issue and hope to have it resolved soon.
You can also try using the documentation to manually create your own custom coordinate system (https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/coordinate_sys_custom_about.htm)
Also the custom Coordinate System tool is available to use.
I will update this thread once we resolve the issue.
Thanks you!
Donal
daveatsafe
Forum|alt.badge.img+19
Hi @delunama,
fme.ly/coordsys
delunama
Participant
  • Participant
  • May 2, 2024
Perfect, that works! Thank you for the quick turnaround.
