Find when a map service was last used?
fmegrinder
My customer want me to automate a report how many times diffrent map services has been reqested.
It’s on a unfederated arcgis server with arcgis server manger.
In arcgisserver manager i can export this information one by one to a csv file and get how many times a service has been requested in a set time period.
I need to find a way to automate this process. Is it possible to retrieve this statistics using FME and then print it to an Excel file? Then on FME-server I need to get a report every month how many times diffrenbt map services has been used.
Best answer by hkingsbury
Have a look at the ArcGIS Admin API - https://developers.arcgis.com/rest/enterprise-administration/server/overview.htm
You can then use a HTTPCaller to send requests
  • April 10, 2024
fmegrinder
  • April 12, 2024
Thank you! I found some information that could work there!
