I have a project to automate creating an OWX file to import into IHS Kingdom Geoscience project. I can manually download an OWX well header file from Enverus Prism. This file is in ascii format and can be viewed in Notepad ++ . I do not see a transformer the can read or write the wellheader.asc file. My guess is I would need to create a custom transformer and then parse the data. Landmark may be the original vendor to use this OWX file format.
