Specify Extension Filters, working in Workbench, but not in Flow app
tdun
Hi all,
I have a workbench which has a parameter that asks for a .ZIP file for input.
Specifying extension filters works in workbench - user can only add/view files with an extension “.ZIP”
When i publish this to FME Flow, and create a flow app, the extension filters are ignored and the user can select/view any file of any type.
Bug?
Using FME 2023.2.0.0.
FME Flow 2023.2, Build 23747 - win64
thanks
Forum|alt.badge.img+53
  • March 27, 2024
I believe that has always been the case (don’t have a version prior to 2023.2 to check with). It means you need to do file extension checks in your process (which is a good thing to do regardless)
pmcpherson
Forum|alt.badge.img+9
  • June 5, 2024
I just now noticed this as well, @tdun. Another responder mentioned he thought it had always worked that way, but I don’t recall that. I see it as a bug, but others may disagree.
