Domains GDB
  • March 20, 2024
  • 41 views
franco69
Hi all,
i have following problem
i join a gdb (with included domains) with an excel sheet…...if i don’t resolve the domains the feature class is written but no geometry
if i resolve the domains i have geometries right but no domains anymore
Can somebody help me?
Thx
Franco
kailinatsafe
Forum|alt.badge.img+21
Hello @franco69, thanks for posting! What version/build of FME Form are you using? It may be helpful if you are able to share a sample workspace and input dataset where I can reproduce the issue? It might be helpful to see how the workspace is designed as well, to see if the join is causing issues or if an attribute is being dropped somewhere in the translation. Happy to help, Kailin.
