I’m using FME Workbench 2023.1. I have an excel file with a Payment Type attribute field. There are 4 types:
- Cash
- Check
- Credit Card
- Money Order
Not all payment types will be present in the excel file each time this is run, but I need it to still have an output for that payment type. I’m fairly new to FME and used an Attribute Filter transformer to filter for each Payment Type, but when there are no rows in my excel file with a particular Payment Type, I will not get any kind of output. See below image for example of one of the areas in my script where I use this filter. I think I need to create a domain of values for the the Payment Type field, before this is run and maybe get a count? In the end what I need is if there are no payments of that type in the Payment Type field, then when I sum the payment amounts for each Payment Type, that particular Payment Type would need to be given an output sum of, 0. If you look in my below image, the only Payment Type that has an output is Credit Card, thus I will get a value for my sum. The other Payment Types have no output.
