Simplify fme_surface
marta.podsiad
Forum|alt.badge.img+9
Hi, I am trying to simplify .stl file that is a fme_surface.
I am trying to get from this
to this
I have tried MeshSimpifier and Triangulator+MeshSimplifier but it failed
Best answer by takashi
Hi @marta.podsiad ,
Just an idea.
  1. GeometryPartExtractor (Geometry XQuery : This part Geometry Type = Mesh part) : Decompose the Mesh geometry into individual Mash parts (Faces).
  2. SurfaceDissolver : Dissove asjacent faces on the same plane into a single face.
  3. Aggregator : Aggregate resulting faces into a MultiSurface.
  4. GeometryCoercer : (Geometry Type : fme_composite_surface) : Transform the MultiSurface to a CompositeSurface.
  5. GeometryCoercer : (Geometry Type : fme_mesh) : Transform the CompositeSurface to a Mesh.
Hope this helps.
takashi
Forum|alt.badge.img+19
  • March 2, 2024
Hi @marta.podsiad ,
Just an idea.
Hope this helps.
marta.podsiad
hi @takashi
Thank you for your message. Unfortunately, mesh simplification went too far while I was following recommended approach.
