Active choice for custom transformers not working in version 2023
xabi
Forum|alt.badge.img+11
I have a workbench build in version 2022 using active choice to enable and disable parameters based on other parameter values. This option stopped working in the new 2023 version.
Does anyone know if the active choice is discontinued?
saraatsafe
Forum|alt.badge.img+9
  • February 9, 2024
Hi @xabi, I don’t believe active choice is discontinued; this may be a bug. Would you be able to file a support ticket for this so we can take a closer look? It would be helpful if you could include your workspace as well. Please let me know if you have any questions on this!
xabi
  • February 12, 2024
Hi @saraatsafe, I just created a case to solve it. Thanks!
