Uploading multiple files with the REST API
  • Sep 25, 2017 4:04 PM UTC
  • 175 views
jdh
Forum|alt.badge.img+41
Were trying to use the REST API to upload multiple files for processing in a web application.
However each file ends up in a separate directory.
$(FME_DATA_REPOSITORY)/{RepositoryName}/{workspacename}.fmw/{UniqueCode}/{filename}
So when we have have tiffs (not geotiffs) and tfws, the world files are not in the same directory as the image file, and therefore are not used by the tiff reader.
Any thoughts on how to keep the auxiliary files with the main file? Unfortunately creating a zip file is not feasible.
Best answer by larry
Maybe you can upload to the resource folders and point your workspace reader to the resources.
  • Sep 25, 2017 4:18 PM UTC
steveatsafe
Forum|alt.badge.img+16
For 2017.1 http://<localhost>/fmerest/apidoc/v3/#!/resources/add_post_11... as @larry mentions. This can upload multipart or more than one file, and each file won't get put into a unique folder... unless of course your code is creating this unique folder and you are uploading files in multiple posts using http://<localhost>/fmerest/apidoc/v3/#!/resources/add_post_13.
