Upload files into SFTP server on a schedule
  • April 17, 2020
  • 208 views
fmeuser_gc
Forum|alt.badge.img+8
Trying to upload .SHP files into SFTP server using scheduler. I've tried FTPCaller and 'Upload to SFTP server' action (in FME 2019.1 Automation) but it doesn't authenticate and throws this error -
Ensure correct host key is listed in the known hosts file
In Automation, I've uploaded private key in SSH format to resources folder and passed it to 'Path to Hosts file' parameter. It doesn't get authenticated but was able to connect to SFTP server in WinSCP via private key. Not sure if the private key has to be in SSH format or PuTTY format for FME. Firstly can this be done?
Also tried in FTPCaller with 'Upload from an Attribute' transfer type, but not sure of the URL value as it only has hostname and username.
Please suggest. Thanks in advance!
Best answer by siennaatsafe
Hi @fmeuser_gc,
Thanks for posting this question. Unfortunately, private SSH keys are not supported in the SFTP external action. However, do have instructions on using Public SSH keys here https://docs.safe.com/fme/html/FME_Server_Documentation/WebUI/Automations-External-Actions/Ext-Action-SFTP.htm
As for a workaround, you can use the FTPCaller as detailed here by Debbi and Gerhard https://knowledge.safe.com/questions/66175/how-do-i-use-sftp-ssh-keys-to-download-a-file.html If you are using FME Cloud you will have to use Gerhard's method. However, Debbi's solution should work fine on a local FME Server.
If you have any issue please let me know.
Kind regards,
Sienna
siennaatsafe
Forum|alt.badge.img+11
  • April 20, 2020
Hi @fmeuser_gc,
Kind regards,
Sienna
