Python problem after upgreading to FME Desktop 2019
Hi all,
I have problem with small script removing accents from letters, it worked fine in FME Desktop 2018 and after upgrading it to 2019 gives me errors like:
Python Exception <NameError>: name 'unicode' is not defined
Error encountered while calling function `strip_accents'
API_POI_Name-strip (PythonFactory): PythonFactory failed to process feature
A fatal error has occurred. Check the logfile above for details
Bridge failed to output feature on tag `PYOUTPUT'
Why is so?
import fme
import fmeobjects
import sys
import reload(sys)
sys.setdefaultencoding("utf-8")
import re
import unicodedata
def strip_accents(feature):
n1 = feature.getAttribute('Name_1')
n2 = feature.getAttribute('Name_2')
nkfd_form = unicodedata.normalize('NFKD', unicode(n1))
t1 = u"".join([c for c in nkfd_form if not unicodedata.combining(c)])
nkfd_form = unicodedata.normalize('NFKD', unicode(n2))
t2 = u"".join([c for c in nkfd_form if not unicodedata.combining(c)])
feature.setAttribute('Name_1', t1)
feature.setAttribute('Name_2', t2)
Best answer by david_r
Python 2 and Python 3 are not fully compatible, if you have a script developed for Python 2 you will, in most cases, have to modify it to run under Python 3.
This is particularly the case for anything dealing with unicode, as this was fundamentally changed in Python 3.
There is a tool that can help in migrating code from Python 2 to 3:
https://docs.python.org/2/library/2to3.html
  • May 29, 2019
Is your workspace maybe configured for Python 3?
  • May 29, 2019
Yes, it should be so. Scripting-> Python Compatibility is set on 'Python 3.5+'
  • May 29, 2019
Did you use Python 3 when running the workspace under FME 2018 as well?
  • May 29, 2019
Good question. I think it was 2.7. But I've tried to change Python interpreter on 2.7 and 3, as it is in the options but errors stayed the same. How should I proceed to make it work?
  • May 29, 2019
  • May 29, 2019
Thank you very much for the link! Small changes done and everything works perfect!
