python caller for loops
  • February 14, 2020
  • 6 replies
  • 107 views
Hello,
I want to calculate slope between neighbor points. I want to use python caller to do something like take the first point (pointID is smallest) go to the next one , calculate the slope between the points and write it in a new attribute (_slope). Then go to the next point (so 2nd and 3rd) calculate slope and save the value.
I am new with python in fme, so could you help me?
Best answer by paalped
import fmeobjects
from functools import reduce
from math import sin, pi
def left_slope(feature_a, feature_b):
    # Note last feature wont have a slope attribute cause there is no feature to compare With
    a_x = float(feature_a.getAttribute('x'))
    a_y = float(feature_a.getAttribute('y'))
    a_z = float(feature_a.getAttribute('z'))
    b_x = float(feature_b.getAttribute('x'))
    b_y = float(feature_b.getAttribute('y'))
    b_z = float(feature_b.getAttribute('z'))
    # NOTE!! Evaluate formula before using, this is just from the far back of my head
    planar_distance = ((a_x-b_x)**2 + (a_y - b_y)**2)**(1/2)
    delta_z = b_z - a_z
    slope_degree = sin(delta_z/planar_distance) * 180 /pi
    feature_a.setAttribute('_slope', slope_degree)
    return feature_b
class FeatureProcessor(object):
    def __init__(self):
        self.features = []
    def input(self,feature):
        self.features.append(feature)
    def close(self):
        reduce(left_slope, self.features)
        for feature in self.features:
            self.pyoutput(feature)
Here is a funky solution. It assumes feature are sorted by your point ID definition.
Forum|alt.badge.img+32
  • February 14, 2020
If the points are in order, this can be done without using a python caller using Adjacent attribute handling. If you have the coordinates exposed, by selecting enable adjacent feature attributes and choosing 1 subsequent feature, you can access the coordinate attributes of the next feature to use in whatever formula you are using for calculating a slope.
paalped
Forum|alt.badge.img+5
  • February 17, 2020
import fmeobjects
    delta_z = b_z - a_z
    return feature_b
    def __init__(self):
        self.features = []
    def close(self):
  • February 17, 2020
paalped wrote:
import fmeobjects
    delta_z = b_z - a_z
    return feature_b
    def __init__(self):
        self.features = []
    def close(self):
Thank, it solved my problem. Now I want to multiply the slope_degrees the same way (first point * secod pont, second point * third point). I am using the following script, but it gives an error, like:
Python Exception <TypeError>: float() argument must be a string or a number
Traceback (most recent call last):
  File "<string>", line 23in close
  File "<string>", line 9in left
TypeError: float() argument must be a string or a number
PythonCaller_3(PythonFactory): PythonFactory failed to close properly
PythonCaller_3(PythonFactory): A fatal error has occurred. Check the logfile above for details
Here is my code, can you help me where is my mistake?
import fme
import fmeobjects
def left(feature_a, feature_b):
    a_z = float(feature_a.getAttribute('_slope'))
    b_z = float(feature_b.getAttribute('_slope'))
    _slope_elojel = b_z - a_z
    feature_a.setAttribute('_slope_elojel', _slope_elojel)
    return feature_b
    def __init__(self):
        self.features = []
    def close(self):
        reduce(left, self.features)
paalped
  • February 17, 2020
paalped wrote:
import fmeobjects
    delta_z = b_z - a_z
    return feature_b
    def __init__(self):
        self.features = []
    def close(self):
I totally forgot to mention to use coordinateextracor first to extract x,y,z from index 0 on a point feature class. Sort by pointID
paalped
  • February 18, 2020
paalped wrote:
import fmeobjects
    delta_z = b_z - a_z
    return feature_b
    def __init__(self):
        self.features = []
    def close(self):
Hi, I think this error message will occure at the last feature processing. Cause _slope is missing on the last feature. you need to add a condition before casting to float. I can look at it tomorrow.
paalped
  • February 19, 2020
import fme
import fmeobjects
    return feature_b
    def __init__(self):
        self.features = []
    def close(self):
Here is an update:
import fme
import fmeobjects
def isnumeric(x):
    try:
        float(x)
        return True
    except:
        return False
    # Note last 2 feature wont have a _slope_elojel attribute cause there is no feature to compare With
    a_z = float(feature_a.getAttribute('_slope')) # exists in our case
    # Last feature_b has no slope
    b_z = feature_b.getAttribute('_slope')
    if isnumeric(b_z):
        b_z = float(b_z)
    return feature_b
    def __init__(self):
        self.features = []
    def close(self):
