Proxy-problem when using ArcGIS Portal Feature Service Reader (MalformedPacError)
ireen
Forum|alt.badge.img+5
We have a model where we use a ArcGIS Portal Feature Service Reader. On the FME Desktop machine, the model works fine for me but not for my colleague. On the FME Server, the same error pops up as my colleague gets.
In the logs, there is the following message when the model fails (on Dekstop for my colleague and on the FME Server):
511 2023-3-31 00:32:15 | ArcGIS Portal Feature Service Reader: Logging into 'https://URLarggisportal/' as user 'username'
512 2023-3-31 00:32:15 | Python Exception <MalformedPacError>: Malformed PAC file (ReferenceError: identifier 'myIpAddressEx' undefined
513 2023-3-31 00:32:15 | duk_js_var.c:1258
514 2023-3-31 00:32:15 | FindProxyForURL src\\pyduktape.c:41
515 2023-3-31 00:32:15 | eval src\\pyduktape.c:1 preventsyield)
When I run the model myself on FE Desktop, I get this log and everything works fine:
2023-03-31 10:34:00| 117.4| 0.3|INFORM|ArcGIS Portal Feature Service Reader: Using proxy http://proxy.url:port/
2023-03-31 10:34:00| 117.4| 0.0|INFORM|ArcGIS Portal Feature Service Reader: Logging into 'https://URLarggisportal/' as user 'username'
2023-03-31 10:34:00| 117.4| 0.0|INFORM|ArcGIS Portal Feature Service Reader: Using proxy http://proxy.url:port/
2023-03-31 10:34:01| 117.4| 0.0|INFORM|ArcGIS Portal Feature Service Reader: Getting item with ID '55283d731dc8498088b712b8d5a4cd33'
How can we fix this on desktop and server?
Best answer by wouter
You could try to define a “Custom Proxy Map” (Tools > FME Options > Network Proxy). Make sure that the URL field points to the target URL you are trying to reach and that the No proxy option is enabled.
ireen
  • November 29, 2024
Did you find a solution for this? We have the same issue on FME Form; on server it works fine.
wouter
Participant
  • Participant
  • February 11, 2025
