Is it possible to truncate the table of a non-hosted Feature Service using FME Flow?
We're trying to create a near-live view of our data, differing from the majority of content on our ArcGIS Enterprise which comes via registered Feature Services (source - Oracle database). We're unable to update the production dataset more often than the current weekly schedule due to internal constraints.
We're aware that FME can update a Hosted Feature Layer but can it update a non-hosted Feature Service? I.e. one which is being referenced from a database via an SDE?
nielsgerrits
Forum|alt.badge.img+54
Why not update SDE using FME?
Because any updates we make to SDE are only pushed from dev to prod once a week - we need to update some services more often than this (but are unable to serve them up as Hosted Feature Layers).
nielsgerrits
Clear. I'm not sure what you mean with the non-hosted Feature Service?
In my understanding the different options are:
  • AGOL
    • Hosted services (source is datastore)
  • Portal
    • Federated services (source is SDE)
From your list above - I'm referring to a federated service. Our source is a database (via SDE).
The answer to my question could be no, just exploring the option.
nielsgerrits
Yes, it is possible to do a truncate and insert in a federated feature service in portal.
