How to collect all files in a folder into one ZIP-file
Does someone have a workspace example how to collect all files in a folder for creating a ZIP-file to send to the Mailer-transformer?
I am using FME Desktop 2022
Best answer by nielsgerrits
FeatureWriters to write the result to a folder. Sampler to collect the summary features from the FeatureWriters and let the last one pass to initiate the ZipArchiver from the hub to create a zip from the folder.
danilo_fme
Forum|alt.badge.img+44
  • June 22, 2023
Hello @arlvanbijleveld​
What kind of files do you want to extract?
nielsgerrits
Forum|alt.badge.img+54
  • June 22, 2023
This approach worked for me! I joined the Emailer to the Output-port of the ZipArchiver, as I discovered that the Logsuccess-port would send as many emails as the amount of files in the folder.
Thanks @nielsgerrits​ for your help!
nielsgerrits
Lol I think everyone using the Emailer has had the mailbomb experience. If it was bad enough, you will not make this mistake again.
