Has anyone tried using FME to connect CityWorks to Kronos time keeping? We'd like to have the time codes sent directly to Kronos instead of having someone manually enter them in.
  • May 24, 2023 8:11 PM UTC
  • 52 views
keziaatsafe
Forum|alt.badge.img+8
Hi @candimk​ ,
I personally have not tried sending information to UKG/Kronos but if they have an API endpoint that you can connect with, it should be possible. You can connect to APIs using the HTTPCaller transformer.
Here are some resources that may help you get started:
Hope this helps!
Kezia
