Getting Started with APIs
  • Nov 4, 2016 6:32 PM UTC
  • 85 views
I am trying to connect to Woocommerce's API and extract some information and then tie orders to a map service and update a field. I am really new to working with API's and need some basic info on what I need to start. I would like to make a call to the API statement below and return a table, this is similar to the Workbench I have attached. Any help from existing documentation or a start on a work bench would be great. Thanks
API Call Doc: http://woocommerce.github.io/woocommerce-rest-api-docs/#list-all-orders
I think HTTPCaller should do it for you. The URL will be similar to the WooCommerce API documentation example you reference:
https://example.com/wp-json/wc/v1/orders using a GET and where example.com is your website.
The header name in the HTTPCaller will be consumer_key and the value of will be your API key. Don't include the colon (:) in the header name. FME will do that for you. Something like:
itay
Forum|alt.badge.img+19
  • Nov 5, 2016 1:01 PM UTC
Tip: for readability I usually set the Response Body Encoding to system default (fme-system)
erik
Participant
  • Participant
  • Dec 26, 2018 8:10 PM UTC
How would the workpace look like, if you want to get all the geometries of all the Strava activities?
danilo_fme
Forum|alt.badge.img+58
  • Dec 26, 2018 10:30 PM UTC
Hi @erik
Please,check the Workspace uploaded by @piercexc. There is a Bookmark called Create GeoJSON geometry.
Thanks,
Danilo
