FME Server REST API: return the SDE connection string?
annette2
Forum|alt.badge.img+10
I am using the API to generate an inventory of our server FME workspaces for an upcoming migration
Can you return an SDE connection string that isn't a published parameter?
Example call:
http://stdcap-koaa-001/fmerest/v3/repositories/BASISDATA/items/KLIC.fmw/datasets/destination
Response:
[  {    "format": "GEODATABASE_SDE",    "name": "GEODATABASE_SDE_1",    "location": "",    "source": false,    "featuretypes": [      {
The location is "".
For an Oracle Spatial connection:
http://stdcap-koaa-001/fmerest/v3/repositories/BASISDATA/items/KLIC.fmw/datasets/source
 Response:
[  {    "format": "ORACLE_SPATIAL",    "name": "ORACLE_SPATIAL_1",    "location": "BI@PDB1",    "source": true,    "featuretypes": [      {
Dgn and Excel readers/writers also have a filled location string.
Am I missing something?
Thanks,
Annette
Best answer by david_r
I'm not quite sure that's possible. If you need more information about a specific workspace, you may want to consider downloading the workspace and analyze it further using the FME workspace reader:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/fmw/Feature_Representation.htm
  • August 14, 2019
annette2
  • August 14, 2019
Thanks David. Great tip. Got it working. I was going to resort to reading the workspace in a text file. I didn't know this was an option.
