FME Server IMAP publisher - could not find publisher
  • May 3, 2017 11:44 PM UTC
  • 54 views
Hi all,
I am trying to set up an imap publisher, but everytime I try to save it it comes up with the error 'Could not find publisher'. The same error applies when I try to validate the publisher. All required fields have been filled in on the publisher.
I don't know what the error means as I can't find any reference to it in any documentation.
It looks like all my publishers aren't working as the directory watch publisher doesn't seem to pick anything up either.
Any ideas?
Thanks
ciarab
Forum|alt.badge.img+10
  • May 4, 2017 12:12 AM UTC
@gisballarat This also happened to me last week. A previously working IMAP publisher stopped and when I went to check why I saw the same error message. I deleted the publisher and recreated but still kept getting that message. Once I restarted the services and created the publisher again it then validated and it's working fine now. I'm not sure why it happened I would like to know myself as I'm not sure how long it was down before I actually realised there was a problem.
Unfortunately I have tried to delete, restart and add and still receive the same error
ciarab
  • May 4, 2017 12:29 AM UTC
Strange.... I definitely only did the restart I played around with it for a while and there was nothing in the log files to explain what was causing the problem. I think i ended up restarting twice. First time I didn't delete the publisher and when I checked it still wasn't working. Second time I removed the publisher before restart and it worked. It's the only publisher I had on that server so when i restarted the publisher list was blank not sure if that makes any difference
rylanatsafe
Forum|alt.badge.img+14
Hi @gisballarat - This one sounds very strange! Is there anything suspicious in the log files?
core\\fmeserver.log, core\\fmeprocessmonitorengine.log, core\\publishers\\imap.log
