FME Desktop works fine but fails when published to FME Server
  • Oct 23, 2017 9:25 PM UTC
  • 56 views
dfresh
Hey Folks,
I created a working fmw on desktop, executes fine on desktop, fails on server.
notes
  • login to server, copy fmw and data, executes as expected
the fmw has the following logic
  • SQL executor (this runs succesfully)
  • Reader - Esri Geodatabase (File Geodb Open API)
  • Reader - Esri Geodatabase (File Geodb)
however in the log, it fails because of the following (image below).
my understanding is it only should use a BASIC/ARCVIEW license for the File Geodb format. however not sure what is happening here. perhaps it has to do with the user level running the engine? no clue.
Best answer by brianatsafe
Hi @dfresh,
I suspect that the user that is being used to run the FME Engine may not have permission to access the ArcGIS License. Here is a good article that explains this: https://knowledge.safe.com/articles/24153/using-fme-server-with-esri-software.html
Try what is suggested in the "FME Engine Service Account Requirements" section.
Also, ensure that you are using both 64bit FME/Esri or 32bit FME/Esri products as mixing these will not work. Hope that helps!
brianatsafe
Forum|alt.badge.img+13
  • Oct 23, 2017 11:23 PM UTC
Hi @dfresh,
