FME Data Inspector 2017.1: Failed to fetch Feature Types for Background Map
Can you set a background map in FME Data Inspector 2017.1 (build 17539)?
I got this error when retrieving feature types for a Background Map.
  • August 4, 2017
Got the same error with both AGOL and Stamen background map:
Forum|alt.badge.img+49
The Stamen map works fine on my Mac, also build 17539. On my Windows machine it seems to take an awful long time trying to determine the coordinate system of the background map (even when there's no data loaded in DI yet), but I'm also running a big raster mosaicking job at the same time so that might mess things up. I'll try again when that's done.
  • August 4, 2017
It seems that the error will occur when Python 2.7 is used as the default interpreter. After changing the "Preferred Python Interpreter" to 3.5+ in the FME Options from Workbench, then I was able to set a background map.
fmelizard
Forum|alt.badge.img+18
  • August 4, 2017
Hi @takashi, @redgeographics and @david_r. Does the issue still occur in 2017.1.1? 2017.1.1 is available here. There is a known issue which has been resolved in 2017.1.1, noted in the Workarounds to known issues in FME 2017.x article and it may be related. Thanks.
