Hello, I'm having a problem when trying to write records from an ESRI file geodatabase feature class to an ArcGIS Online hosted feature service. The error message in the log is as follows: ArcGIS Online Feature Service Writer: Encountered an unexpected error. The error code from the server was '504' and the message was: 'Your request has timed out.'. Details: '' Any ideas on how to resolve this issue? Thanks.
FGDB to AGOL Connection Times Out
Best answer by markatsafe
@firegis In 2019.1 and higher we've added (so not in Esri Data Interoperability Extension yet) we have added some smarter timeout re-try for AGOL based readers/writers upon encountering an HTTP 500/502/503/504 responses. Hopefully this will address you timeout issues.
