extracting a substring using python caller
  • Dec 8, 2016 4:31 PM UTC
  • 6 replies
  • 133 views
arthy
Forum|alt.badge.img+8
I wrote a very long workspace and at some point I want to extract a substring of the filename using the python caller and have it as a new attribute in my workspace.
Then I tried to write a workspace with only that instruction (see attached) but I'm still having the same error:
Python Exception <KeyError>: 'fme_basename'
Error executing string `fme_basename=FME_MacroValues['fme_basename']
def thm(fme_basename):
    return fme_basename[4:]
Factory proxy not initialized
PythonFactory failed to process feature
test.fmw
Any idea of what could be the problem?
Thanks
Best answer by david_r
Try this:
def thm(feature):
    basename = feature.getAttribute('fme_basename')
    if basename:
        basename = basename[4:]
        feature.setAttribute('fme_basename', basename)
Let me know if you don't understand what, how, etc.
  • Dec 8, 2016 5:00 PM UTC
Try this:
def thm(feature):
    if basename:
courtney_m
Forum|alt.badge.img+23
  • Dec 8, 2016 5:02 PM UTC
You could use a SubstringExtractor within the long workspace, instead of the PythonCaller:
And you can set the Result Attribute name to whatever you want.
  • Dec 8, 2016 5:13 PM UTC
Yup, definitely a lot easier.
arthy
  • Dec 9, 2016 1:32 PM UTC
Thanks @courtney_m.
It's a good alternative but it does not help me to understand the problem with the python caller.
arthy
  • Dec 9, 2016 1:35 PM UTC
Try this:
def thm(feature):
    if basename:
@david_r,
Now I see my error.
I have also tried using fme macro values to get the attribute and I see with your suggestion that the good one is feature.getAttribute.
Many thanks
  • Dec 9, 2016 1:56 PM UTC
@david_r,
Now I see my error.
Many thanks
The FME_MacroValues dictionary is for published/private parameters only, where as the getAttribute() and setAttribute() methods are only for feature attributes.
If you want to learn more, I recommend this free webinar: http://www.safe.com/webinars/python-scripting-in-fme/
