Email (IMAP) stop working after 7 days
martin
Forum|alt.badge.img+3
We load in FME Server 2017 backup from FME Server 2014. Specified Email (IMAP) publications was validated and it was ok. After 7 days FME Server stop getting mails and we have to push validate again. Is there any configuration for this or how to make it work without stoping?
Hi @martin
Do you notice anything amiss in the email log? If you navigate in the Resources to Logs > Core > Current > Publishers > email.log
steveatsafe
Forum|alt.badge.img+12
  • December 11, 2017
jlutherthomas wrote:
Hi @martin
Also @martin, Confirming the IMAP service is precisely the same and was not changed to say Office365? I've had another issue where this service stops working after some days.
Please share the log that jlutherthomas asked about.
zzupljanin
Forum|alt.badge.img+4
  • September 21, 2018
I'm working on this issue also. email.log doesn't give anything much (picture below). Also, IMAP service remains unchanged.
Cheers,
Zelimir
siennaatsafe
Forum|alt.badge.img+10
zzupljanin wrote:
Cheers,
Zelimir
Hi @zzupljanin,
Would you mind sending the imap.log? It's in the same folder as the email.log.
Thanks,
Sienna
zzupljanin
  • September 24, 2018
siennaatsafe wrote:
Hi @zzupljanin,
Thanks,
Sienna
Hi, Sienna
log is provided szgdds3-imap.txt
I've hidden e-mail address for security reasons.
siennaatsafe
zzupljanin wrote:
Hi, Sienna
Hello @zzupljanin,
It could potentially be occurring on the side of the email provider. Could you talk to whoever manages the email accounts and see if they can find anything on the email side which may say if/why they're disallowing the connection?
How often are you polling the imap service? If you make it less frequent will it still stop after 7 days?
Thank you for sending the log. It looks normal, would you mind looking through the old logs when the configuration stopped working and see if there is more info on that day? Were there any errors in the log?
Thanks,
Sienna
zzupljanin
  • November 23, 2018
siennaatsafe wrote:
Hello @zzupljanin,
Thanks,
Sienna
Yeah, sorry for not replying. I couldn't find anything wrong in logs from days later. It seems that this problem randomly occurs. It took some time (few months) since last occurence.
We've contacted e-mail administrator. They didn't touch anything on their side for few years.
Service is polling every 1 minute. We can't go lower than that.
Just an idea: If we delete this IMAP service and create new one (with same parameters) from scratch... can it work? Gonna try that and see what happens next few weeks.
I'd appreciate any new idea
Cheers.
todd_davis
Forum|alt.badge.img+22
  • November 25, 2018
I can't answer the "why" in relation to the Imap issue, but this is similar to the issue we had with a network directory watching at a client, that was caused by a network disconect due to something (e.g. backup, etc). Again, it was fixed by validating. So we validate Notifications (via schedule) on all our FME Server and our clients FME Servers at least daily. And we remove any websocket connections created by topic monitoring. Attached is the FME Workspace...with the end removed, so you can decide how you notify yourself (we utilise SMS).
We also monitor our abiity to send and receive emails from FME Server, but that is a far more complex process, and not one that I can share.
notifications.zip
siennaatsafe
Cheers.
Hello @zzupljanin,
I'm sorry you are experiencing this issue again. I would try recreating the IMAP service and trying again. Or you could try what Todd suggested above. If you are still encountering an issue, could you please open a support case? https://www.safe.com/support/report-a-problem/
Kind Regards,
Sienna
cwarren
  • December 31, 2018
I'm having a similar issue too with FME Server 2018.1.1 in which it will stop polling an IMAP e-mail address. This is a huge issue and I hope it can be fixed soon as I have filed a report with Safe about it.
zzupljanin
  • July 4, 2019
notifications.zip
Hi, this is really nice.
Another same problem occurred recently. We're considering applying your workaround.
One question though:
On last step, I see you're testing if http response is 204. If it is, all is ok. If it's not then you send SMS.
Why are you testing 204 and not 200?
I'm only getting 200 response, which does seem that is ok, but your tester sends this to send SMS portion.
Regards,
Želimir
todd_davis
  • July 5, 2019
Regards,
Želimir
Hi @zzupljanin,
I'm on holiday at the moment, so no don't have FME software close at hand, but I looked at the process in a texteditor. I believe the tester that references an http status 204 follows httpcaller_7. That httpcaller is a "Put" and appears to be working on updating a subscriber.
From the documentation a 204 is a success for this call...https://demos-safe-software.fmecloud.com/fmerest/apidoc/v3/#!/notifications/put_put_28
Cheers,
Todd
