Define Output Dataset to include in Datastreaming services when publishing with FME server REST API
  • Sep 13, 2016 3:12 PM UTC
  • 72 views
jpvo
When using the REST API to publish a workspace on FME server, you can register a service but if you register a datastreaming service you can't specify the dataset to include as output of the service.
In my experience, the first publication of your workspace must be done using the workbench and anytime you want to republish it you can use the API.
Anyone found a solution?
I'm facing the same problem but with datadownload service. Unfortunately, I have not yet found a solution.
According to the answer of @larry on this post
https://knowledge.safe.com/questions/33872/define-sucessfailure-topics-when-publishing-worksp.html#comment-34370, here is a workaround :
fmelizard
Forum|alt.badge.img+22
  • Sep 22, 2016 11:53 PM UTC
Using the REST API to do this is an interesting approach. We've not developed for this scenario, but that doesn't mean we wont. Would you be willing to add this to the Ideas exchange?
https://safe.com/ideas
You can add details on your scenario and others can contribute their thoughts too. The more votes your idea gets, the more likely it will be completed.
