I am new using Oauth2 authorization protocol, so please, don't blame on me if I make sillyquestions.
I am triying to access the API of Idealista (a real state company) to get information about the offer they have about offices, warehouses, etc. I got from Idealista an Apikey and a secret and I used this information to get a token making an http request like this:
POST https://api.idealista.com/oauth/token?grant_type=client_credentials&scope;=read HTTP/1.1
Accept-Encoding: gzip,deflate
Content-Type: multipart/mixed; boundary="----=_Part_7_1090412765.1526401548680"
MIME-Version: 1.0
Content-Length: 45
Host: api.idealista.com
Connection: Keep-Alive
User-Agent: Apache-HttpClient/4.1.1 (java 1.5)
Cookie: APIPUBID=3d5ed4374026f476|WvsKD|WvsKD
Cookie2: $Version=1
Authorization: Basic anFndmhtaGRxNmZmazBtNWY1cjZuNG1hNGYzdTNncG86bmw3VHhqQ2cybWU3
Once I get the token as a result of the previos http request, I can make a new request in order to obtain the information I am looking for. Here you have an example:
POST https://api.idealista.com/3.5/es/search?locale=es&maxItems;=20&numPage;=1&operation;=saleℴ=publicationDate&propertyType;=garages&sort;=desc&apikey;=jqgvhmhdq6ffk0m5f5r6n4ma4f3u3gpo&t;=1&language;=es&bankOffer;=true&locationId;=0-EU-ES-28 HTTP/1.1
Content-Type: application/json
Authorization: Bearer eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJzY29wZSI6WyJyZWFkIl0sImV4cCI6MTUyNjQ0NDY5MSwiYXV0aG9yaXRpZXMiOlsiUk9MRV9QVUJMSUMiXSwianRpIjoiMDJhNzdhODQtODlhYi00MzAyLWI5Y2QtODFkNDc4OWJjMGIwIiwiY2xpZW50X2lkIjoianFndmhtaGRxNmZmazBtNWY1cjZuNG1hNGYzdTNncG8ifQ.CZulxxvMXZvuIt_UDMeXiKC9wsnTgZw-y__7-DSaHQc
Content-Length: 0
I have tested the previous process in SoapIUI successfully and now I am trying to reproduce this in FME Desktop. I tried to make a new "Web connection" with the information included in the attached image. When I test the connection I get this message:
{"message":"not found","httpStatus":404}
Idealista has not provided me any information about the "refresh token" url, so I put the same as for the "retrieve token". On the other hand, the "grant_type" parameter I have to specify when making the "retrieve token" request (as stated by Idealista) has to be "client_credentials", meanwhile in the FME form, this parameter is fixed as "authorization_code".
Any help will be more than welcome. Many thanks.
Hi @jcglez2
It looks like the requirements of the Idealista API are not supported by the current OAuth 2.0 Web Conecctions template. The Token service requires both headers and parameters, and on top of that the credentials have to be base64-encoded.
However, you can easily use this API using 2 HTTPCallers, one for the Token service and another one for the Property Search service. I tried it using the following workflow and it worked
Hi @jcglez2
Thanks a lot @NathanAtSafe for your support with this issue!
