Connect to sql server on my local machine
  • Aug 8, 2021 3:09 PM UTC
  • 7 replies
  • 610 views
dor1411993
Hello everyone!
There is a SQL Server named on my local machine, for testing purposes.
I can not connect the fme to sql, no matter what I write in the login line,
He's giving me an error.
What am I doing wrong?
Thank you!
sql
itsmatt
Forum|alt.badge.img+48
  • Aug 9, 2021 6:50 AM UTC
Can you connect to it with other tools other than FME. Are you sure the 'Server:' is correct?
dor1411993
  • Aug 9, 2021 7:02 AM UTC
Hey @virtualcitymatt​ ,
Thanks for answer me.
In fact no,
I tried through GIS, and failed.
I'm relatively new to SQL, maybe I'm not writing the address properly?
This is what it looks like in SQL settings:sql
itsmatt
  • Aug 9, 2021 7:10 AM UTC
Try and use localhost as the hostname, this should just be your computer. I'm not familiar with SQL Server either, however, usually hostnames are just a computer/server. When something is running on your own computer you can use localhost.
dor1411993
  • Aug 9, 2021 7:21 AM UTC
Thank you,
But it still does not work ..
Maybe need to put a specific IP address?
itsmatt
  • Aug 9, 2021 7:28 AM UTC
Thank you,
Hmm, ok maybe try .\\SQLEXPRESS
From here: https://stackoverflow.com/questions/11425275/connecting-to-sql-server-express-what-is-my-server-name
or localhost\\SQLEXPRESS
Perhaps you'll find some other helpful info in the link above
dor1411993
  • Aug 9, 2021 7:33 AM UTC
Thank you,
Still nothing..
I think it has to do with the definition of the SQLSERVER itself ..
But I did everything according to the instructions.
nielsgerrits
Forum|alt.badge.img+67
Probably related: https://community.safe.com/s/article/workarounds-to-known-issues-in-fme-2020x
FME Desktop: SQL Server driver missing in the installer
Problem: If attempting to connect to SQL Server on a new system with no previous install of FME Desktop 2020.0, you may encounter a missing driver error.
Workaround: If you are unable to connect to a SQL Server database, install the MSOLEDBSQL driver that is present in the FME Desktop installer. Searching in your FME install directory for 'MSOLEDBSQL' should bring up the installer. If you run that installer, and re-launch FME Workbench it should connect to SQL Server as expected.
