ArcPy - ERROR 001269: Compressing the service definition failed. Failed to execute (StageService).
  • Feb 21, 2019 12:01 PM UTC
  • 5 replies
  • 161 views
jeand
Hi guys,
I developed a solution for a client to prepare locators by using ArcPy module. In 32 bit it's working fine.
But the client use a FME Server 2017 64 bit. I tested the solution with in 64 bit and now I have an issue with an ArcPy function.
Python Exception <ExecuteError>: ERROR 001269: Compressing the service definition failed.
The function is arcpy.StageService_server. I did some research on web and the only solution I found it's to run it in 32 bit. But like I said before, the client uses FME Server 64 bit.
Any one have a solution for this situation?
Regard,
Jean
jeand
  • Feb 21, 2019 3:18 PM UTC
Finally I found a workaround!!!
I needed to create an external call to Python ArcGIS 32bit and passing parameters needed to call the function StageService_server. In this way, even if I run in 64bit, the subprocess is running in 32bit and it worked.
If someone needs more details on how to achieve this, let me know and I will post my solution.
Regards,
Jean
  • Jul 12, 2019 10:35 PM UTC
Regards,
Jean
I'm struggling with the exact same issue currently. It would be great if you could share your solution for how you are calling the 32bit Python! Thanks :)
jeand
  • Jul 16, 2019 11:53 AM UTC
Hi Sonya,
There is the workspace used to call Python in 32 bit.
You will find 2 private parameters, one for the path where is located the python.exe in 32 bit version and one where the Python scripts are located.
You probably need to modify how to pass parameters to your Python Function, but I think this is a good starting to understand how to achieve it.
  • Jul 16, 2019 7:45 PM UTC
Hi Sonya,
Thanks Jean! This is a great workaround! Works like a charm. Thanks for offering up your solution :)
Regards,
Jean
Hi Jean,
Would you please share your solution for how you are calling the 32bit Python!
Much appreciated!!
Thanks,
Tiemin
Email: tsheng8797@gmail.com
