Open
Warn when resolving ArcGIS Domains if code (value) not found in Domain (FGDB/Arc
Related products:Integrations
  • Jul 2, 2019 12:00 AM UTC
  • 160 views
tim_wood
Forum|alt.badge.img+8
***Note from Migration:***
Original Title was: Warn when resolving ArcGIS Domains if code (value) not found in Domain (FGDB/ArcSDE)
For example when reading a File Geodatabase or ArcSDE layer.
It is possible for a field in a layer to contain a value that doesn't match a code (value in FME speak) in the Domain. For example your Domain has:
1 = Car
2 = Bus
3 = Train
But the Vehicle field for some features in your layer have the value "4" in the actual data. Even worse, the value in the data might be "Car" which makes it almost impossible to figure out that ArcGIS is showing the raw data and not displaying "Car" by looking up "1" in the Domain.
When you read the data into FME (whether you use the FGDB Open API Reader or the ArcGIS Reader), you will get an empty string for any values such as "4" that aren't in the Domain. This is because FME will look up the actual value from the data and not find it in the Domain.
I would like to suggest that if this happens, the Log file should record a Warning or Error to say something like "WARN: code '4' not found in Domain 'Vehicle_type'".
sammy
Forum|alt.badge.img+27
  • Jan 18, 2024 9:04 PM UTC
This would be especially helpful now with the Utility Network. Has any functionality been added that would facilitate flagging records where domain code not found?
sammy
  • Mar 6, 2024 3:56 PM UTC
It would also be great to have the option of just putting the unresolved code in the _resolved field (maybe along with the warning)
sammy
  • Mar 7, 2024 5:36 PM UTC
I put in a new idea suggestion to include the option in addition to a warning. Not sure if that is redundant? But here is the link to upvote:
