Released
Reader for OSM data in pbf format
Related products:FME Form
  • December 8, 2015
  • 14 replies
  • 138 views
jdh
Forum|alt.badge.img+41
I would love the ability to read OSM data in pbf rather than xml format http://wiki.openstreetmap.org/wiki/PBF_Format
embeezy
Forum|alt.badge.img+7
  • March 23, 2016
This is something we could use big time as OSM is the most important source for us in any time of crisis.
jdh
  • March 23, 2016
@mb_fdfa I do have an inelegant solution using scripted paramters and OSMConvert where there is a published parameter (Filename (Existing) with a configuration of *.pbf;*.osm;*.o5m;*.osm.gz and the OSM reader points to a scripted parameter. Mine is more complicated with filtering and clipping options, but it boils down to
import os.path import subprocess
#get parameters
inOSM = FME_MacroValues['OSM']
toolsDir = FME_MacroValues['OSMTools']
#get osm basename
(filepath, ext) = os.path.splitext(inOSM)
#create temp output file
outOSM = filepath + '-temp.osm'
#Create and run OSMconvert command line
runP = toolsDir+'/osmconvert ' + inOSM + ' -o=' + outOSM
subprocess.call(runP)
#return temp filename
return outOSM
fmelizard
Forum|alt.badge.img+22
  • June 14, 2016
File size differences are huge (11GB in pbf, 171GB in XML) this would really save some space/processing if we could get the pbf format.
fmelizard
  • August 8, 2016
@jdh @d2 @mb_fdfa -- I can advise that an Open Street Map PBF Reader has been in FME 2017 betas since build 17037 -- we've had no feedback on it yet and so would definitely welcome some. Thanks for your interest!
jdh
  • August 16, 2016
Are there plans to allow for common osm feature types like those available in the osm reader (highway, waterway, natural, etc), or will it only support data primitives (nodes, ways, relations).
fmelizard
  • August 19, 2016
Thanks for the feedback. To be clear, you'd prefer the features be emitted with feature types more like the OSM reader? We'll look and see what we can do -- it does seem very reasonable.
jdh
  • August 19, 2016
The osm reader has a parameter as to whether to use basic (node/way/relation), broad (highway), specific (highway_primary) or user defined (fmi pipeline file).
The pbf reader uses the gdal osm config .ini, which produces nodes/way/relations. Even something like offering alternate config files with the distribution would be beneficial*, though my preference would be a parameter.
*Most of my users would not be able to create a custom config file.
  • December 22, 2016
Will there be a pbf writer as well?
  • January 10, 2017
Is there a way to try this reader in FME 2016 already?
fmelizard
  • January 10, 2017
You need to grab FME 2017 betas to try it, but these can co-exist with FME 2016.
fmelizard
  • January 19, 2017
No plans at the current time for a PBF writer. Feel free to suggest as an Idea so we can track interest.
embeezy
  • January 31, 2017
Finally I have FME 2017 on my main Workstation and can try the new reader. Thanks, great it is there!
Although I haven't been able to try any real scenarios yet, I think that the suggestion from @jdh would be a useful enhancement.
This has been released as part of FME 2017.0 . Visit http://www.safe.com/downloads to download it and give it a spin.
brianatsafe
Forum|alt.badge.img+13
  • November 14, 2017
Hi @jdh,
I'm pleased to let you know that the 2018.0 version of the now reader allows you to choose from the 26 broad categories and its sub categories (via OSM Map Features), which are represented as feature types similar to the OSM XML reader.
Let us know how it looks!
