Archived
Process started by the SystemCaller should end if workspace is aborted
Related products:FME Form
  • February 25, 2019
  • 34 views
itsmatt
Forum|alt.badge.img+48
I've been experimenting with the System caller to run third party command line tools. It works great for the most part, however, when you stop the workspace the called process keeps running.
It would be nice if the call could be killed/cancelled when the FME process is aborted.
The problem is compounded when the sub process leverages the folder created by the TempPathNameCreator - If the FME process is aborted then these files do not get cleaned up.
Idea comes from this QA: https://knowledge.safe.com/questions/87473/process-triggered-from-system-caller-does-not-end.html
harmen_kampinga
It would also be great to have more info why a process keeps running.
More logging info needed!
