Released
New Writer: IFC
Related products:Integrations
  • July 17, 2017
  • 12 replies
  • 416 views
davideagle
Forum|alt.badge.img+22
Writing data to IFC at the moment in FME is a little bit of guesswork because the target schema is so focused as to what is "allowed in". With formats like GPX, when you add the Writer it lays down for you the permissable FeatureType names and attributes, giving you at least a starting point and an indication that calling a layer "Bob" or "Test1" isn't going to get you too far.
In the short term it strikes me that perhaps a template that helps to show how to set Names, Traits and Geometry Names might be a good starting point.
conterra_chrisc
Forum|alt.badge.img+4
In addition it would be very helpful to improve the writer to support IFC extension like IFC-Bridge and IFC-Road (http://www.buildingsmart-tech.org/infrastructure/projects)
atle_hoidalen
Forum|alt.badge.img+3
Hope to see some improved functionality making it easier to use this writer. Maybe it could be set up like the IMX-writer where you choose predefined featuretype from the IMX-schema definition like conterra_chrisc suggests?
davidrasner5
Yes, please. There is endless potential in exchaning data using IFC files. It's way too technical at the moment.
LizAtSafe
Forum|alt.badge.img+24
  • October 11, 2024
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
  • October 11, 2024
LizAtSafe
  • October 11, 2024
LizAtSafe
  • October 11, 2024
LizAtSafe
  • October 11, 2024
LizAtSafe
  • October 11, 2024
The IFC writer is being re-written and we are hoping to address all of the related ideas that have been merged above. Please add any use cases or comments to this idea.
Gathering InterestIn Development
LizAtSafe
  • July 7, 2025
In DevelopmentReleased
daniii
Forum|alt.badge.img+7
  • August 6, 2025
@LizAtSafe Why does the new IFC writer support only 3D surfaces and solids and not 2D line geometries?
One of the greatest new features of the IFC4x3 schema is that we can write 2D lines to IFC, which was not supported in IFC2x3.
PierreAtSafe
Forum|alt.badge.img+11
  • September 2, 2025
See my answer in
In Short: We are working on it for 25.2.
