Writing data to IFC at the moment in FME is a little bit of guesswork because the target schema is so focused as to what is "allowed in". With formats like GPX, when you add the Writer it lays down for you the permissable FeatureType names and attributes, giving you at least a starting point and an indication that calling a layer "Bob" or "Test1" isn't going to get you too far.
In the short term it strikes me that perhaps a template that helps to show how to set Names, Traits and Geometry Names might be a good starting point.
In addition it would be very helpful to improve the writer to support IFC extension like IFC-Bridge and IFC-Road (http://www.buildingsmart-tech.org/infrastructure/projects)
Hope to see some improved functionality making it easier to use this writer. Maybe it could be set up like the IMX-writer where you choose predefined featuretype from the IMX-schema definition like conterra_chrisc suggests?
Yes, please. There is endless potential in exchaning data using IFC files. It's way too technical at the moment.
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
The IFC writer is being re-written and we are hoping to address all of the related ideas that have been merged above. Please add any use cases or comments to this idea.
Gathering InterestIn Development
In DevelopmentReleased
@LizAtSafe Why does the new IFC writer support only 3D surfaces and solids and not 2D line geometries?
One of the greatest new features of the IFC4x3 schema is that we can write 2D lines to IFC, which was not supported in IFC2x3.
See my answer in
In Short: We are working on it for 25.2.
