Archived
Find and Replace function for given attribute
Related products:FME Form
  • Sep 18, 2024 9:40 AM UTC
  • 135 views
judith
Observer
Forum|alt.badge.img+4
renaming an attribute in large workspaces oftentimes takes a lot of time because of the related manual adjustments needed.
I would appreciate a function that is able to change a given attribute to another given attribute within a whole workspace in every Transformer and Writer.
Best regards
Judith
bwn
Forum|alt.badge.img+26
  • Sep 19, 2024 1:36 AM UTC
Similarly would note that this is desirable but there is an existing Transformer that almost does this already: NullAttributeMapper
NullAttributeMapper is currently mis-named.  It actually does do All/Selected Attribute search and replace for more than just Nulls.  It will look for any fixed value, or any RegEx pattern.
What it is missing, is the ability to use the current attribute value in the replacement function, + more broader comparator support such as > , < , LIKE, IN() etc.  Otherwise it is actually very close to an “All Attribute Search/Replace”
denniswilhelm
Forum|alt.badge.img+21
The result might be the same, but it’s only a hotfix and the workspace will only get more complicated.
I think the initial idea is more about refactoring Workspaces and therefore changing all occurences of specific elements (like attributes) throughout the Workspace. If you rename user parameters then the change will be applied everywhere. This is different with attributes. If I change an attribute early in the Workspace all following transformers will be invalid.
I guess a more general idea would be to provide a Search & Replace funtionality. Right now you can only search for strings in FME Form, but a replace is missing.
LizAtSafe
  • Sep 19, 2024 9:29 PM UTC
Updated idea statusNew→Archived
Idea merged into:
All the votes from this idea have been transferred.
