Open
ChangeDetector alternate comparison of decimal and datetime values
Related products:Transformers
  • Mar 23, 2020 12:00 AM UTC
  • 75 views
burgasser
Forum|alt.badge.img+5
When using the ChangeDetector to compare attribute values, decimal and datetime values create false-positives due to precision (i.e. 10.00 vs. 10.0001). Perhaps comparison of decimal values could be done via abs(value1 - value2) > epsilon. The user could enter the epsilon value. Dates vs. DateTimes could be handled similarly.
kketola
Forum|alt.badge.img+14
  • Jan 17, 2025 11:05 PM UTC
Was just pulling my hair out with this today. It wasn’t a matter of close precision like the post but I inserted into SQL Server from an Oracle dataset and because of differences in how the data was represented by each vendor, it wouldn’t match. 25.8 <> 25.80000000 according to ChangeDetector but was flagged as a duplicate by DuplicateFilter.
I ended up using a regex replace in an attribute manager to trim trailing 0s, but more control over decimal and datetime matching is worth an upvote!
