Archived
Attribute Validator - Populate _fme_validation_message (string) with a concatena
Related products:FME Form
  • September 5, 2016
  • 34 views
jhawkins
Participant
***Note from Migration:***
Original Title was: Attribute Validator - Populate _fme_validation_message (string) with a concatenated string of failure messages that appear in the list
When a record fails more than one attribute test I think it would be a good idea if _fme_validation_message (string) contained a concatenated string of all the list element messages that have failed, not just the first one.
Eg.
At present you get this
I think it would be more useful if _fme_validation_message (string) contained “Attribute 'DevelopmentAddress' fails check for Has a Value', Attribute 'ApplicantSurname' fails check for Has a Value”
The reason I ask is that I wish to create an error report that details all the issues that have occurred to each record in one line of the report. I also want a string that I can easily search and count to identify records that failed, certain elements.
The list elements are very useful and I certainly want to see these kept, but if the above is implemented it would save a lot of work which now has to go into producing a one line message from the resulting list.
Forum|alt.badge.img+54
  • September 5, 2016
Why not just add a ListConcatenator on the _fme_validation_message_list ?
