Released
Add Rejected-port to the PythonCaller
Related products:Transformers
  • Mar 22, 2016 12:00 AM UTC
  • 19 replies
  • 555 views
It would be very helpful to have a Rejected-port on the PythonCaller.
Outputting a failed feature could e.g. look like this:
self.pyoutput_failed(feature)
This would simplify the pattern where you need to set a temporary attribute to indicate success/failure, then a Tester and then removing the temporary attribute.
  • Mar 22, 2016 11:18 AM UTC
I like it. It might be ideal if the user could add (and rename) output ports optionally. How about this?
self.pyoutput(feature) # to the topmost port self.pyoutput(feature, 'port_name') # to an additional port
  • Mar 22, 2016 12:50 PM UTC
Even better :-)
geosander
Forum|alt.badge.img+7
  • Mar 22, 2016 1:04 PM UTC
Yes, that would be really great! Filtering on the spot. I now always tag my features with some attribute and use a TestFilter afterwards or something.
jdh
Forum|alt.badge.img+41
  • Mar 22, 2016 2:51 PM UTC
That is a great idea, I think 90% of the time my pythonCaller is immediately followed by a tester/TestFilter to separate the results.
ekkischeffler
How about an additional port for a failing Python script instead of making the whole workspace fail?
  • Nov 10, 2016 11:48 PM UTC
Yes please - this would be an enormous improvement :)
  • Jan 23, 2018 5:31 AM UTC
It would be great if this port included a Line Number, Type Name and settable Context attribute, e.g.
import sys ... context = '' try: parsed_json = json.loads('{...}') #some valid JSON for k, v in parsed_json.items(): context = k # do stuff except Exception as e: error = 'Error on line ' + str(sys.exc_info()[-1].tb_lineno) + ' - ' + str(type(e).__name__) + ' - ' + str(e) + '. Context: ' + context print error feature.setAttribute("_error", error)
chriswilson
Forum|alt.badge.img+29
  • Mar 8, 2018 11:31 PM UTC
This really would help, too often the python caller errors are difficult to debug and having the features outputted through this port would be great.
tcrossman
  • Mar 21, 2022 4:15 PM UTC
Why not go whole hog and have a Python-based transformer designer API?
LizAtSafe
Forum|alt.badge.img+26
  • Feb 10, 2024 5:58 AM UTC
The following idea has been merged into this idea:
All the votes have been transferred into this idea.
LizAtSafe
New→In Development
LizAtSafe
  • Feb 10, 2024 5:59 AM UTC
Updated idea statusIn Development→In Technical Review
danilo_fme
Forum|alt.badge.img+58
  • Feb 24, 2024 3:03 PM UTC
It can be very interesting for all users.
vlroyrenn
Forum|alt.badge.img+14
  • Mar 12, 2024 4:12 PM UTC
Seems like it has been added to FME 2024.0, according to fmetools.
vlroyrenn
  • Mar 14, 2024 8:42 PM UTC
I’m noticing a few things with the 2024.0 changes to support this in the underlying PythonFactory:
  • The PythonCaller itself hasn’t yet been modified to allow multiple ports
  • The default template of the Transformer Designer still uses an upstream TeeFactory and a downstream TestFactory to simulate multiple output ports instead of plugging all ports in the PythonFactory directly
  • Calling self.pyoutput(feature, "<REJECTED>") will end the workflow as soon as the Rejected feature appears, like most other transformers, but a raised exception (not even an FMEException) will not be turned into a rejected feature. Errors still need to be properly caught and the feature created by the exception handler.
  • The close() method only fires once and does not have a per-port identifier, meaning a Python script cannot validate that individual input ports have finished sending data. This means transformers that need to wait for all features to have come through to start outputting can’t do so independently between ports, and order-critical operations can’t be asserted.
vlroyrenn
  • Mar 14, 2024 8:44 PM UTC
 I made a 2024.0-only PythonCaller clone with a <Rejected> port just to try it out and show how it works. I can’t attach any files here, and this is by no means tested enough to be uploaded to FME Hub, so I’m just going to dump the contents of the FMXJ file here.
Documents\FME\Transformers\PythonCallerRejectable.fmxj
"info": {
"categories": [
"Workflows"
"comments": [
"name": "PythonCallerRejectable"
"versions": [
"changeLog": [
"Initial version of transformer"
"comments": [
"================================ Version 1 ========================================"
"executionTemplate": [
"FACTORY_DEF {*} PythonFactory",
" FACTORY_NAME { $(XFORMER_NAME) }",
" PY_INPUT_TAGS Input",
" $(INPUT_LINES)",
" SYMBOL_NAME { $(PYTHONSYMBOL) }",
" PYTHON_NAMESPACE FMEOBJECTS",
" SOURCE_CODE { $(PYTHONSOURCE) }",
" PY_OUTPUT_TAGS Output <REJECTED>",
" OUTPUT { Output FEATURE_TYPE $(OUTPUT_Output_FTYPE)",
" $(OUTPUT_Output_FUNCS) }",
" OUTPUT { <REJECTED> FEATURE_TYPE $(OUTPUT_<REJECTED>_FTYPE)",
" $(OUTPUT_<REJECTED>_FUNCS) }",
"featureHolding": "none",
"form": {
"parameters": [
"name": "TRANSFORMER_GROUP",
"parameters": [
"name": "XFORMER_NAME",
"prompt": "Transformer Name",
"showEditButton": false,
"supportedValueTypes": [
"none"
"type": "text",
"valueType": "string"
"prompt": "",
"type": "group",
"defaultValue": "",
"name": "PARAMETERS_GROUP",
"parameters": [
"defaultValue": "FeatureProcessor",
"editor": "plaintext",
"name": "PYTHONSYMBOL",
"prompt": "Class to Process Features",
"required": true,
"showArithmeticEditor": false,
"showInlineEditor": false,
"showPrompt": true,
"none"
"trimWhitespace": true,
"type": "text",
"defaultValue": "import<space>fme<lf>import<space>fmeobjects<lf><lf>class<space>FeatureProcessor<openparen>object<closeparen>:<lf><space><space><space><space><quote><quote><quote>Template<space>Class<space>Interface:<lf><space><space><space><space>When<space>using<space>this<space>class<comma><space>make<space>sure<space>its<space>name<space>is<space>set<space>as<space>the<space>value<space>of<space>the<space><apos>Class<space>to<space>Process<space>Features<apos><lf><space><space><space><space>transformer<space>parameter.<lf><space><space><space><space><quote><quote><quote><lf><lf><space><space><space><space>def<space>__init__<openparen>self<closeparen>:<lf><space><space><space><space><space><space><space><space><quote><quote><quote>Base<space>constructor<space>for<space>class<space>members.<quote><quote><quote><lf><space><space><space><space><space><space><space><space>pass<lf><space><space><space><space><space><space><space><space><lf><space><space><space><space>def<space>has_support_for<openparen>self<comma><space>support_type:<space>int<closeparen>:<lf><space><space><space><space><space><space><space><space><quote><quote><quote>This<space>method<space>is<space>called<space>by<space>FME<space>to<space>determine<space>if<space>the<space>PythonCaller<space>supports<space>Bulk<space>mode<comma><lf><space><space><space><space><space><space><space><space>which<space>allows<space>for<space>significant<space>performance<space>gains<space>when<space>processing<space>large<space>numbers<space>of<space>features.<lf><space><space><space><space><space><space><space><space>Bulk<space>mode<space>cannot<space>always<space>be<space>supported.<space><lf><space><space><space><space><space><space><space><space>More<space>information<space>available<space>in<space>transformer<space>help.<lf><space><space><space><space><space><space><space><space><quote><quote><quote><lf><space><space><space><space><space><space><space><space>return<space>support_type<space>==<space>fmeobjects.FME_SUPPORT_FEATURE_TABLE_SHIM<lf><space><space><lf><space><space><space><space>def<space>input_from<openparen>self<comma><space>feature:<space>fmeobjects.FMEFeature<comma><space>input_tag:<space>str<closeparen>:<lf><space><space><space><space><space><space><space><space><quote><quote><quote>This<space>method<space>is<space>called<space>for<space>each<space>feature<space>which<space>enters<space>the<space>PythonCaller.<space><lf><space><space><space><space><space><space><space><space>Processed<space>input<space>features<space>can<space>be<space>emitted<space>from<space>this<space>method<space>using<space>self.pyoutput<openparen><closeparen>.<lf><space><space><space><space><space><space><space><space>If<space>knowledge<space>of<space>all<space>input<space>features<space>is<space>required<space>for<space>processing<comma><space>then<space>input<space>features<space>should<space>be<space><lf><space><space><space><space><space><space><space><space>cached<space>to<space>a<space>list<space>instance<space>variable<space>and<space>processed<space>using<space>group<space>processing<space>or<space>in<space>the<space>close<openparen><closeparen><space>method.<lf><space><space><space><space><space><space><space><space><quote><quote><quote><lf><space><space><space><space><space><space><space><space>try:<lf><space><space><space><space><space><space><space><space><space><space><space><space>#<space>foo<space>=<space>1<solidus>0<lf><space><space><space><space><space><space><space><space><space><space><space><space>self.pyoutput<openparen>feature<comma><space><quote>Output<quote><closeparen><lf><space><space><space><space><space><space><space><space>except<space>Exception<space>as<space>exc:<lf><space><space><space><space><space><space><space><space><space><space><space><space>feature.setAttribute<openparen><quote>fme_rejection_code<quote><comma><space><quote>error<quote><closeparen><lf><space><space><space><space><space><space><space><space><space><space><space><space>feature.setAttribute<openparen><quote>fme_rejection_message<quote><comma><space>str<openparen>exc<closeparen><closeparen><lf><space><space><space><space><space><space><space><space><space><space><space><space>self.pyoutput<openparen>feature<comma><space><quote><lt>REJECTED<gt><quote><closeparen><lf><space><space><space><space><space><space><space><space><space><space><space><space><lf><lf><space><space><space><space>def<space>close<openparen>self<closeparen>:<lf><space><space><space><space><space><space><space><space><quote><quote><quote>This<space>method<space>is<space>called<space>once<space>all<space>the<space>FME<space>Features<space>have<space>been<space>processed<space>from<space>input<openparen><closeparen>.<quote><quote><quote><lf><space><space><space><space><space><space><space><space>pass<lf>",
"editor": "python",
"name": "PYTHONSOURCE",
"prompt": "Enter Text Data",
"required": true,
"showInlineEditor": true,
"showPrompt": false,
"none"
"type": "text",
"valueType": "stringEncoded"
"prompt": "Parameters",
"required": false,
"type": "group",
"inputPorts": [
"name": "Input"
"outputPorts": [
"name": "Output"
"attributesAdded": [
"name": "fme_rejection_code",
"type": "buffer"
"name": "fme_rejection_message",
"type": "buffer"
"name": "<REJECTED>"
"upgradeWarning": "",
"version": 1
vlroyrenn
  • Mar 15, 2024 4:55 PM UTC
I made that last point into its own idea, since it would be an expansion on what has already been added to fix the current one.
andreaatsafe
Forum|alt.badge.img+17
I’m pleased to let you know that we have added a rejected port to the PythonCaller via the reject_feature() method.
This is available in the upcoming release of 2024.2, you can try it out now in the beta: https://fme.safe.com/downloads/#beta
LizAtSafe
  • Sep 23, 2024 3:57 PM UTC
Gathering Interest→Released
