Archived
A function that removes diacritics (accents) from strings
Related products:Transformers
  • April 5, 2017
  • 179 views
moberdries
Forum|alt.badge.img+10
If I have a user that needs to interactively do a Road-Name search then road names containing diacritics will fail the search. The workaround is to have 2 road name attributes, one for searching, and one for publishing. For my Road-Name search attribute, I need to be able to strip out the diacritics.
PostgreSQL offers a "unaccent" function to do this - can we have this same capability inside FME StringReplacer or similar?
Refer https://www.postgresql.org/docs/9.1/static/unaccent.html
  • April 5, 2017
Maybe the StringDiacriticRemover from the FME Hub can help?
https://hub.safe.com/transformers/stringdiacriticremover
bruceharold
Forum|alt.badge.img+19
  • April 6, 2017
Mike, these are Maori macronated vowels in your context aren't they?
You could build something from the attached code or build a streetname locator from the style file in this sample:
maori-macrons.py
  • April 7, 2017
For info: I just tried a couple of these macronated vowels with the StringDiacriticRemover and it seems to work:
Input: Th? qu?ck brown fox j?mps over the l?zy d?g Output: The quick brown fox jumps over the lazy dog
