Hi, in FME Flow 2023.2.1 you can´t disable an Active Period once it was successfully created. If you like to disable an Active period but keep the configuration (like a repeat on interval config), you need to remove it or adjust the start/end date.
It would be more helpful to enable/disable an Active Period like it is done in the Job Routing / Engine Assignment rule / Schedule / Automation.
Be the first to reply!
