Released
Add an option in VertexCreator to remove the coordinate attributes
Related products:Transformers
  • September 29, 2023
  • 20 views
bruceharold
When you have created geometry you are usually done with attributes supplying the coordinates, GeometryReplacer has an option to drop them, let's do the same for VertexCreator.
andreaatsafe
Forum|alt.badge.img+10
  • September 12, 2024
This is now available in the upcoming release of 2024.2!
There is now a parameter to “Remove Attributes” in the VertexCreator
LizAtSafe
Forum|alt.badge.img+15
OpenReleased
