Add Timeout Parameters to JSON Readers, you can put a API URL into the json readers and it works, however some API's are really slow and it will timeout. You can work around this by using the HTTP Caller, but having the json reader is a lot nicer, as the reader parses the json into attributes itself.
Be the first to reply!
