The Group By option on transformers with several input ports is usually used with attributes which occur on both/all input ports.
Can there be an option in the attribute selection window to only show attribute names that both input ports have in common?
For instance, on the clipper, both the Clipper and the Clippee should contain the attribute I want to group on. So it would be great if I could display attributes that are existing on both input ports.
Be the first to reply!
