Open
Debug mode for WorkspaceRunner subworkspaces
Related products:Transformers
  • October 29, 2015
  • 12 views
siennaatsafe
fmelizard
danilo_fme
tcrossman
jelle
+10
  • siennaatsafe
    siennaatsafe
  • fmelizard
    fmelizard
  • danilo_fme
    danilo_fme
  • tcrossman
    tcrossman
  • jelle
    jelle
  • revesz
    revesz
  • marcel_conterra
  • mccorkdm
    mccorkdm
  • moberdries
    moberdries
  • mygis
    mygis
  • ddecoene
    ddecoene
  • kweller
    kweller
  • vyaenec
    vyaenec
  • voltagex
  • firework_girl
fmelizard
DEBUG mode for workspaces called by WorkspaceRunners. For linked worksheets I would like to have the option (debug mode if you will) for the caller to open multiple copies of FME (if not already open for that target worksheet) so that you can see what is going on, instead of running it like a command line. There is nothing more frustrating than debugging a target worksheet when having to manually populate the published parameters so you can figure out what went wrong.
kweller
Forum|alt.badge.img+8
  • October 11, 2016
This should apply to custom transformers as well, including linked.
