Archived
FME floating licences support IPv6
Related products:FME Form
  • November 25, 2016
  • 6 replies
  • 27 views
rylanatsafe
siennaatsafe
fgiron
+4
  • rylanatsafe
    rylanatsafe
  • siennaatsafe
    siennaatsafe
  • david_r
  • fgiron
    fgiron
  • qmarquette
  • frro
    frro
  • peterjbaldwin
  • lundopendata
  • steveatsafe
    steveatsafe
Please could FME floating licences be supported over IPv6.
I would second that. We use Microsoft Direct Access for all laptops, which relies on IPv6 and so FME desktop is unusable with a floating licence.
  • January 11, 2018
A possible workaround is documented here.
On the client, create a batch file with the following two lines and execute with admin privileges.
setx FNP_IP_PRIORITY 6 /m setx FNP_IP_ENV 1 /m Do not run the batch file on the server.
fmelizard
Forum|alt.badge.img+17
  • January 11, 2018
  • January 11, 2018
Yes, that's the source of my comment below :-) Credit where credit is due, thanks Stephan!
  • January 11, 2018
There is a workaround according to this this Autodesk forum page: You need to set two environment variabls, which allows you to use FME both with and without Direct Access (i.e. with IPv6 and IPv4). Put these two lines in a batch file:
Setx FNP_IP_PRIORITY 6 /mSetx FNP_IP_ENV 1 /m
Hope this helps.
Stephan
PS: Kudos to our internal support team for figuring this out.
  • January 11, 2018
According to our support team and
https://forums.autodesk.com/t5/installation-licensing/not-able-to-obtain-a-license-over-ipv6-directaccess-ipv6/m-p/6603258/highlight/true#M160532, you need to set two environment variables, for example in a batch file:
