If you have multiple attributes that you want to split the same way, e.g. by pipe or space, it would be useful to have an option in the AttributeSplitter to do this rather than having to insert multiple attribute splitters one after the other. You would specify the delimiter and then in a separate section all of your attributes - you could toggle which ones you want to split and give the list name for each one there and then.
Page 1 / 1
I have published a custom transformer named MultiAttributeSplitter in FME Hub. Hope it would be a workaround in the interim.
Cheers Takashi, looks pretty helpful.
