***Note from Migration:***
Original Title was: Text size in the JSON XML transformers for the XQuery text editor too small on Mac
When using any of the XML JSON - Templater, Flattener, etc. when entering the query in the text editor, the font is so small it's unreadable on a Mac. It will not allow you to change the text size and none of the zoom options work. Other text editors are ok on the Mac.
I've observed similar behavior on Windows configured with high-DPI settings. This was not only in the text editor, but also in some dialogs such as the workspace publishing wizard.
OpenReleased
In 2023.1, we made some improvements to the text editor on macOS. In the options of these dialogs, you can also increase the font size to make the text even larger. If you're still experiencing issues, please file a ticket for our team here: https://support.safe.com/hc/requests/new
