Write Sharepoint hosted file to temp-folder
  • Jun 2, 2022 1:05 PM UTC
  • 73 views
Hi together,
I am working with the SharepointOnlineConnector and was successfully downloading the file to any local directory. However, when trying to download the file from SharePoint to the FME sharedresources temp folder, it doesn't seem to work:
When running the workspace on FME Server, it rejects everything
UnbenanntDo you know by chance what I am missing here?
Thanks
Ferid
merlinegeorge
Hello @fungergis​
Downloading the file from SharePoint to the FME_SHAREDRESOURCE_TEMP folder should be possible. Would you be able to provide the error message or job log for further troubleshooting?
  • Jul 12, 2022 7:55 AM UTC
Hi @Merline George​
sorry for that late response.
When checking the logs on the server, it is just rejecting the file
I don't know why ... I could successfully write some outputs to temp on the FME Server via FeatureWriter... but using SharePointOnlineConnector, it seems to fail...
