WMS
  • July 22, 2020
  • 33 views
I am testing workbench: GetCapabilities.fmw and GetPNG.fmw to publish WMS service. I use sample data from https://knowledge.safe.com/articles/19640/how-to-create-a-wms-service-using-fme-server.html. I get WMS adress URL, but when I want to open the WMS in FME Desktop/QGIS I get information "Received HTTP response header: 'HTTP/1.1 401 from ......." Any suggestion what can be wrong? Propably, it's problem with authorisation, what options should I change in security (FMe Server)?
daveatsafe
Forum|alt.badge.img+19
  • July 22, 2020
Hi @atbober,
If you are using FME Server 2019 or 2020, I would recommend creating Server Apps (https://knowledge.safe.com/articles/94277/fme-server-apps.html) from those workspaces. This will allow you to turn authentication off.
