I drop files in FME server (upload) but these files can not be read in the job
brigousse
DESIGN READER: Error opening Design file RECOLEMENT BT 17-110_4S1_sig.4S1
The same files are properly processed if it's one of my colleagues who drops it
Nb: he is in the company premises and I work from home
je depose des fichiers par FME server (upload) mais ces fichiers n'arrivent pas à être lu dans le job
Les même fichiers sont correctement traités si c'est un de mes collègues qui le dépose
Nb : il est dans les locaux de l'entreprise et je travaille de chez moi
philippeb
Forum|alt.badge.img+18
  • August 16, 2019
Looks like a permission problem. What's your files path? Try using UNC path.
I suggest you write everything in English ;) Mais vive la France!
fmelizard
Forum|alt.badge.img+17
  • August 16, 2019
Hi @fred-veremes and @rbomme. Wanted to let you know about this query from Thierry of Etudis. Maybe you have another suggestion as well? Thank you!
abizien
Forum|alt.badge.img+4
  • August 19, 2019
Hi Thierry, can you share your job log file as well as your workspace and the file(s) you try to process? This will help us identify the issue.
